:aigo:
Is it normal for the check engine light to come on after turning up boost???
sorry for the noob question :aigo:
a_sesshoumaru said:it is normal if you are hitting fuel cut wich is code 34, usually in the 12 -14psi range
sneakypete said:i actually had a weird problem over the summer with that. when i was on the highway and boosting around 12-14psi my check engine light would come on after the run, and then shut off after i cruised for a bit. sometime i would even blow off a vacuum line. i wasnt hitting fuel cut. not sure what it was
2543arvin said:Did you ever check the code? Because what you just described sounds like fuel cut...
