1JZ places for tech/swap and parts
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
I thought it might be a good idea to put together a list here for 1JZ tech info and places to get 1JZ parts
I'll start off with what little i have. Send me a PM with what you have and i'll add it to the list. They don't have to be the best places. But just to have what is out there so people can get an idea of there own.
Some of this i took from other sites info pages. some i found on my own but i am sure someone has mentioned it somewhere....lol
Important 1JZ-GTE Japanese TRM Manual Information
http://bobiseverywhere.com/images/supramania/Read_this_or_DIE.pdf
Alternate source
http://dirtystyleracing.org/supraforums/Read this or DIE.pdf
1JZ-GTE TRM
http://www.bobiseverywhere.com/images/supramania/JZ_Series_Engine_Manual.pdf
1JZ Swap Info
http://www.supras.nl/index.php?option=com_content&task=view&id=38&Itemid=54
http://1jz-gte.us/
http://www.autosoftsys.com/supra/index.cfm
Identifying your 1JZ Rev. #1 or #2
http://www.autosoftsys.com/supra/pics/newstylesml.jpg
1JZ Tech and parts info
http://www.turbosupras.com/pages/en/pages/specifications/JZA70/jza70.htm
Great parts refrence ----> http://www.1jzgte.com/tech/JZA70 Parts Reference.html
The intake valve stem seals are part number 90913-02123.
The exhaust valve stem seals are part number 90913-02088.
Front Crank Seal: 90311-46001
Rear Main Seal: 90311-90006
JDM 1JZGTE Part Numbers Provided by 935Motorsports
13568-49025 Timing Belt
13505-46020 Timing Belt Idler
13540-46012 Timing Belt Tensioner superceded by Part Number 13540-46030
90311-38041 Camshaft Seal
90916-02308 Serpentine Belt
1JZ Parts Places
swap parts + other ----> http://store.driftmotion.com/index.php?sid=145322b2716e39&category_id_int=142
some performance parts ----> http://www.suprastore.com/1jzgteparts.html
http://www.mvpmotorsports.com/merchant/supramkiii.shtml#
Our 1JZ Section Link : https://935motorsports.com/catalog/i...Path=79_14_144
BIC Pre 89 motor mount adapter brackets, allow the use of the older square motor mounts with out having to swap crossmembers.
BIC 3" 1jz downpipe, bolt on 3" downpipe, works with the stock cast Y pipe.
www.bicperformance.com
Some information tidbits
Alternator replacment
This was taken froma post by HamsMKIII on another forum
I noticed many references to the MKIV alternator being a direct swap into the 1JZ. It isn't really a direct swap since the plugs on the alternator are different. I accidentally broke my alternator playing around with it (don't ask), so I did a little research on a replacement. Oddly enough, the alternator from a 1992-1994 SC300 only, not 400, is a direct replacement for the 1JZ. It's a perfect fit, and the plugs are identical, so there's no cutting involved. Just plug and play. The best part? The SC300 alternator is a 110 amp alternator. Oh and another great part? I paid $130 with tax for it, lifetime warranty from Lexus. How about that? Funny that the Lexus part ended up being cheaper than the Toyota part. Anyhow, I thought I'd pass along my experience in finding a direct swap for the 1JZ alternator.
- Hams.
This is also from a poster on another forum
OB1 JZA70
"Ok... I have a rare engine... where do I get parts in North America???
I have seen many people asking one of two questions:
A. Where can I get parts for my 1JZ?
B. What parts are interchangable between the 1JZ and the 7M or 2JZ?
I have posted the following list a couple of times on various forums but I figured I should finally post it someplace permanent. So here you go... this is what is interchangable between the 3 engines... the 7M, the 1JZ-GTE, and the 2JZ-GTE. Also below I have added where you can source a few of the other common parts for the 1JZ engine. Anyone who sees errors or has additions please contact me and I will keep this list up to date.
Common parts between the 7M and 1JZ
- Clutch kits (but not flywheel)
- Cat back Exhausts
- 89+ motor mounts (rubber part)
- Anything trans (R154) related
- Anything gauge related
- Rad (if you're not using the 1J hydro fan setup)
- Driveshaft/Diff
Common parts between the 2JZ and 1JZ
- Power steering pump
- Alternator
- Spark plugs (ngk 3330 and 6097)
- US spec 550cc injectors (resistor pack needed)
- JDM Spec 440cc injectors (drop in upgrade)
- Water Pump (requires removal of the 1J hydro fan and a 2J pulley)
- Head gasket (although most other gaskets do not swap, get a 1J set to do it right)
- Clutch fan (if you use a MKIV water pump and pulley)
- Serpentine belt (but NOT timing belt - see below)
- Oil filter and relocation kits
- Intercooler kits
- Plug coils
- Cam gears (incl aftermarket adjustable)
- JDM 2JZ Map sensor
- Ignitor
(edit: some more added info)
1) The rod and main bearings.
2) The head bolts, crank and rod bolts from stock or ARP either bolts or studs w/nuts.
3) The pistons including the wrist pins, wrings and locks.
4) The head gasket, stock or aftermarket.
5) stock side feed or after market side feed high ohm injectors. Low ohm injectors require wiring in the 7M or preferably 2JZ injector resistor pack.
6) Water pump and housing when replacing the hydro fan to electric or clutch fan.
7) Cams are normally not interchangeable with out some grinding on the 2JZ cam and having it spun balanced, HKS, Jun and Blitz all make 256, 264, and 272 cams for the 1JZ.
8) Cam shims, springs, retainers, Valves and springs, along with buckets are interchangeable.
9) turbos are not directly interchangeable and require a degree of machining to swap out the 12As for 12b.
The list will be updated as I remember and acquire more info.
(my edit: i am not sure about this timing belt) has been confirmed bellow by a member that this does work Oct-21-2006
For a 1JZ timing belt:
The 1988+ Isuzu Trooper 4 cylinder 2.6 liter engine (4ZEL) uses the same belt as the Toyota 1JZ engine. So instead of getting a belt from Japan (~$100) you can pick up an Isuzu Trooper belt locally at an auto parts store for about $30 US. Make Sure You Get The 4 Cylinder 2.6 Litre Engine Belt!
Timing belt specs: 137 teeth, 25mm wide
For an aftermarket flywheel:
Order a 7M fly but have the 2J bolt pattern drilled into it.
Very general rule of thumb:
From the Clutch/Trans back it's a regular MKIII Supra (save for the Torsen diffs) From the FlyWheel/Bellhousing forward, it's 70% 1J / 30% 2J parts.
Contact info can be found at the bottom of my main page here:
- Pre-made plug and play harnesses
- Harness extension and conversion service
- 1jzgte single turbo kits and parts
- Hard to find stock 1JZ parts (used)
- Complete swap service (in SoCal)
- 1JZ Lighweight flywheels
- LIVE phone support
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
^^ another great addition to the list! :icon_bigg
also i just poked around your site a bit. what sort of pricing do you guys have on single kits?
Does anyone have a part number for the front and rear main seals? I would like to replace them before I install my motor.............thanks
I would like to get cam shaft seals also for the 1jz.
bobiseverywhere
bobb'n for money
Montreal
goos question i think i should do the same
it would also be good to know what the torque specs are for putting everything back together
Must be a hard question since there is no answer. I'll look for the answer tomorrow, and if I find it then I'll let you know Josh............lol
rakkasan
Currahee!!
Fort Campbell, KY
I just ordered my rear main seal, so when it gets here, I'll give the part number.
Troyota
I Love What You Do For Me
Jul 28, 2005
243
Roswell NM
I've got Front and Rear main seals sitting at home. I will post part numbers up this afternoon when I get home. You should link to Champion/Jay Marks Toyota in Houston...they stock many 1JZ Genuine Toyota parts (that's where I got the seals from).
Please post part numbers. It would be a great help and I will give them a call as well.................Thanks
Troyota
Jul 28, 2005
243
Roswell NM
Ok guys.
I also have Valve Cover gaskets and Camshaft Seals on order. They had run out of their stock (they normally have them, Champion Toyota that is). FYI if they don't have the part they have a 10 week lead time for parts from Japan.
P.S. I don't think it can be stressed enough what a great asset Champion Toyota is to the 1JZ community. Recently JDM parts have become very hard for American Toyota dealers to aquire (I'll have to tell you the story for why that is...the guys at Club4ag weren't too happy w/ me for that one). So, even though I am a Service Manager at a Toyota dealer, they can still get parts that I can't get through my own parts department. If you guys have any want/need for parts that aren't available in America, they are just a phone call away and the worst they can say is no. They are great guys w/ great resources.
