Zankoku Coilovers - Info/Specs
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Hey all,
I'm looking for info on Zankoku Coilovers. I picked up a 91 Hardtop Turbo (Build thread coming soon...) and it's got these coilovers. They are SUPER low as is and need to be raised up so I don't rip off the whole damn bumper. I scrape on my driveway - which is pretty flat - even at 45 degrees and about 0.25 mph. It's ridiculous. The lip has already been damaged and I've driven a total of about 15 miles on the thing.
Anyways... I just got new suspension on my other mk3 and I'm trying to decide which setup to keep. My other car has Koni sport shocks and Tanabe Springs. The ride feels a little better on the Zankoku car, but I'm not sure how much of that is the shocks/springs or just the chassis.
So... Who knows anything about these things? Is there a page somewhere with info? I can't find anything. Are they rebuildable? I hear spring rate is 10-14k.
Thanks!
-Andy
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
SupraDrew;2079338 said:
Watch this video and you should be able to adjust the height.
https://www.youtube.com/watch?v=ozz7HLIhaEI
Thanks, that's a great tutorial on adjustment. However, I'm more after the build specs of the Zankoku system in particular.
That video shows about an inch of exposed case height... I probably have 5-8 inches right now and I can't imagine there's much left to adjust out.
Build specs as far as what?
Standard they came with 14/10 but you could order different spring rates if you wanted. I had them on my old car but I ordered 16/12.
They were pretty decent for being a small name low production coil over.
I'd pick coil overs over spring and shock anyway personally.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I guess my main concern is shock replacement. Are the shock cores/cartridges generally replaceable? The coilovers are less appealing if the whole thing is toast once a shock is blown.
