I'm no expert, just had to do it like 4 times and will have to do so for a 5th(I think, lost count) this week when my Blitz turbos is ready to go back in. :/
The last time, I was lazy and just did it quick and dirty and I have a big exhaust leak but I don't care since they're coming back off soon anyway.:biglaugh:
Ok, a few things that will make your life easier.
1. Don't try to take off the rear intake pipe. You don't need to. The bolts are hard to get to and the pipe really isn't in the way of anything.
2. Leave the oil lines on. Just undo them from the block. That's what I did. Didn't bother to take them off the turbos.
3. It will probably be helpful for you to take some of the studs out of the exhaust sides of the turbos. The ones connecting to the ypipe and the ones connecting to the manifold. Makes it a little easier with some of them out of the way. Loosen up all the nuts holding the turbos to the manifold to the turbo
4. Some people say pull the turbos off as one piece but I took off the front one and then the 2nd one. Leave the manifolds on the head. They don't need to come off but it might help to loosen them a little just to give you some slack. Don't forget to tighten them though. Some of the manifold nuts are hard to get at once you mount the turbos back on and if you don't have the right tools to get to them, you'll have an exhaust leak at the manifold. Happened to me... Was too lazy to take the turbos completely off again to fix it.
5. Don't forget to put the gaskets back on between the turbos and ypipe. I forgot and had to loosen everything up and take the front turbo back off again just to put the gaskets in there. It sucked.
6. Don't forget to tighten all the m
um, that's all that comes to me off the top of my head.
http://www.supramania.com/forums/showthread.php?t=35301
Check out this thread. It's a little cheesy, I know... but some of the pics might help you see what's going on and give you a little guide.
