xtd clutches stage 3 & 4
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
i want to know if u guys think this cluctch is good for a 350-400whp ....its an xtd stage 3 the pressure plate is the upgraded stock one to 2300 pds of clamping load and a 6 puck sprung copper ceramic , throw out bearing and pibot, and aligment tool for about 240 dlls and they also have a stage 4 special order everything is the same except for the pressure plate the clamping load is over 3000 punds and its 399 for that one .....i need a clutch so any comments, suggestions or recommendations are welcome .....
VanSupra
Van,B.C.
lintlars said:
Stay away from those clutches they let go at about 400hp save your cash for a better clutch Ive run two of them and the same outcome both times.
lintlars what reasonably priced clutch have you had success with? Reason I'm asking is a friend of mine is in the market for one right now and will be pushing around 450whp and is i think a little overwhelmed by the amount of choices out there. Thanks in advance.
SupraDreamPDR
Boost-a-holic!!
Feb 3, 2006
1,140
Springfield, OH.
crap. thats what i just bought, plus their 11 lb flywheel.... hope mine holds up.
VanSupra
Van,B.C.
lintlars said:
Im going with the feramic from HPF theres been alot of good things said about it, its a bit pricey but so is buying 2 clutches
Yes I've heard the same about the feramic from others aswell. He's been considering the Spec stage 3 like justin and bigal have suggested but is still undecided. Thanks for the input guys.
fatality
I was speeding?!? NO WAY!
Mar 1, 2006
51
Houston
