xspower intercooler..now some problems
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
ok i just finished my intercooler..piping and everything..now my car spits out black smoke..my friend says in between shifts is when i spit black smoke out the exhuast..and im shifting at 2,000rpm..also my car dies sometimes..and bogs as well..like it not getting enough air..maybe some pipes are loose? my friend said he had to tune his rx7 after he put his intercooler in..need help
MKIIINA
Destroyer of Turbos
Plano, TX
you have a boost leak somewhere. double check your connections and pressure test the system. also did you check the ic before you put it on?
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
yah checked the pipes..turned out to be the same pipe my friend saw loose..i tightened the pipe..and i guess it got loose again somehow..im prolly just going to get some new clamps things..
