Yes i've spent an hour reading all the posts
CAr
89 SUpra turbo 216k 100k in a rebuild motor MHG ARP the whole 9 yard
Diagnose
water pump works because the upper rad hose has pressure
fan clutch works fine
Problem
68 deg tonite driving on freeway notice temp usually sits at 4 oclock but tonite its about 2 oclock running a bit hot
my temperature guage has never moved
turn on the heat it went down
pulled ova no overflow or bubbles on the overflow bottle which is a good thing
noticed that one of my wire on the thermostat housing was broken off , the bottom sensor with one wire blue with white strip
The senosor is on bottom of the thermostat hub where the rad hose goes in to not the housing on the block
anyone knows what the hell this bottom sensor does. ????
i respliced it but would this cuase my car to run hot and move the temp guage???????
also notice tonite after driving the car for 35 min the top rad hose still hard meaning i think my thermostat is stuck close
but did not overhead driving home maybe because i drilled holes in the stock thermostat so that it still would flow a lil when it is stuck
anyone got a clue????? comments are always welcome
Ciao
Lamarossa
CAr
Diagnose
Problem
Ciao
Lamarossa
