WTF - New plugs runs worse
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
So I just put in new NGK BCPR7ES plugs gapped at .028, hoping to fix the slight miss I've been having. Had some denso's gapped around .035 in there, this is the first time I've changed the plugs on the 1jz. I started up the car and now it's missing really bad and you can smell the unburnt fuel.
WTF!
Any ideas? All coilpacks are on the plugs tight, gaps were checked and rechecked and checked again. All the bolts are holding down the coilpacks are nice and tight. The installation went really smooth I wasn't expecting any problems.
Other things to note:
Car was warm ~60c when I started it
It started up right away just fine, then started missing bad
These plugs are 1 level colder than stock (If that would have anything to do with this... :1poke: )
Help :( I wanted to go out tonight and I have work tomorrow too
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
weird only thing i can think of is that one of your coils was slightly cracked before and pulling it off to change the plug made it FUBAR?
only thing that makes sense
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Is there any fix to this or do I have to buy new parts?
I noticed where one of the coils plugs onto its cracked around the base and when I connect the coil the coilpack it moves slightly back and is flexible. The others aren't like this.
I thought maybe I had the frontmost coilpack backwards, but I just flipped it and the car is running basically the same..
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Well Jose aka OneBad7m said I should try putting the stockers back in, so I did, and now the car is running like a champ again. The NGK BCPR7ES just don't wanna fire in my engine. The plugs were still clean, they weren't wet with fuel, but for whatever reason they were making the engine miss really really bad. So thanks Jose! You saved my car tonight and I am utterly thankful cuz I really needed it tomorrow. :thumbup:
soapra
860
VVTi'n, CA
www.kaizenmotorsport.com
Cool! great to hear it help get it back on the road. try the 6097's I got some at the shop. Sorry I didn't get back to you, I was in the middle of dinner.:icon_surp As for gap on those stockers you should be ok with stock gap, I think its in the .030's IIRC.
OneJoeZee
Retired Post Whore
aboard the Argama
Knowing the copper 6097s wear out faster than other plugs, I gap them down a little lower at .28 so I don't have to regap when they start breaking up at .30.
I'm still going on the same set I bought back in January.
But I'm a lazy fucker, so... :dunno:
daneyan
441
South Florida
where do u guys get these plugs. do they have to be special ordered. cause every freaking autoparts store round here doesn't have em.
The Reaper
Jan 10, 2006
1,909
Florida
AZ and Adbacne has them but they usually need to be ordered
i use the Auto lite coppers in mine with NO ill effects at all. runs beatifully. and only 1.00 a plug. BONUS
get em at wal-mart
