Wtf is this?
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
sorry to the owner of the car, but it was the best pic i could find to ask. wtf is the thing i circled in the picture?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
thats the vacume operated valve that opens and closes to allow water into your heater core.. not sure the technical name..heater bypass valve?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
That is a heater control valve. It shuts off the flow of hot coolant to the heater core when you have the A/C on full cold.
Many cars won't have these anymore, or they will be bypassed - the part wasn't terribly well designed and many of them have broken, preventing the owners from getting any heat inside the cabin at all.
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
ahh..... do i really need it connected? it was disconnected since the first day i got the car. never had any problems with it....
whopwood
56
Madison, WI
How often do you need heat in Puerto Rico? ;)
Disconnected = closed, so you are not getting any water circulation thru the heater core.
If you want heat you will need to prop it open. Can do this mechanically (tie wraps for the win!) or just by moving the vacuum supply from the CSV to the top of the actuator can.
Did these valves fail at the VSV or the actuator? Mine is still working :)
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
how often do we need heat in PR? how often do you wish you were a millionaire?
can i just take it out and plug up the hole nearest to the back wall?
shaeff
Kurt is FTMFW x2!!!!
11
Around
heh, i just removed mine completely. :) it cleans up the firewall quite a bit. you'd be surprised. it didnt work, and i dont have A/C, so i didnt need it.
-shaeff
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Yea, you can remove the whole assy, cap off the vacuum at the metal line from the engine. Just get a hose from a parts house that is curved to go straight into the heater core. As everyone said, the valve was designed to stay open except during the coldest (65*) setting on the a/c controls.
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
i removed the whole damn thing yesterday night. all that's left is the black hose that seems to pick up water from the front part of the windshield. didnt touch it yet. can i take that out too or should i just clog it up in case something drips inside?
