WTF? 5psi then 10psi? WTF?
JASONA70
nomnomnom
Oct 27, 2006
743
socal
ok so i took my supra out for a drive today. it was around 3pm and it was like 80-90 degrees outside. i went on the freeway and went WOT. i boosted at 5psi. then at night i went out again around 3AM and i boosted at 10psi. btw i wasnt using a boost controller. i knew i had some boost leak but wtf 5psi then 10psi. that does not make sense. i have semi blown twins.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
yea you'll boost higher in cooler weather...... i boost 11.7 during the day then 14psi (boost cut) at night.
its possible to gain 5 psi do to temperature but you shouldn't be boosting 5 psi during the day at all. thats half of stock boost pressure!!!
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i think i might have a boost leak somewhere near my intake pipes. ill do the boost leak test.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I don't own a 1J, but from seeing a few, i'd guess that the couplers connecting both of the turbo's hardpipes together could start to crack and it would only open up under boost...
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i just installed a brand new intercooler system. i think its my greddy bov. ill make a block off plate and block off the bov area. if not then ill have to make that home made boost leak tester.
