would these fit???
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
Lol, I think those would look horrible.
Why don't you look up the bolt pattern and offset for stock magnum wheels and see for yourself?
MKIIINA
Destroyer of Turbos
Plano, TX
they queation would be why? its got a 225 tire on it. youd probibly be in the same position as the stock tires with lack of width. get something wider
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
hahaha look at the rim size versus tire profile (225/60/18) That wheel would be way too high for the supra as our stock size was 225/50/16
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
18x7.5" F+R
5x115 and +22mm offset.
Both Fronts and Rears would stick out an extra 21mm.
But they're too narrow to be an "upgrade" in any way. Use same size tires + heavier + ugly = downgrade.
/thread
supra4ever68
105
Anaheim, CA
ain't you smart...there is even a girl on this forum that put 18s on the supra with no problem...
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
You are the wrong one. learn to read the tire side wall before you speak please. That tire will not even fit in the tire well. :biglaugh: If it does it will be a real truck now.
bowsercake
828
Irvine, Ca
Anything more than 50 profile is like a truck tire. The GS300 with 16s has a 60 profile tire and it is BIG. So, considering that is an 18 it was either on a really big car or a light truck. Plus,its only 225...
