Scrolling through supras online I find a white fully loaded 5-spd T/T 1989 for sale. I read further into it and find this:
I start to close the window but then i see this:
From the pictures you can see the beginning developments of some surface rust on the hood, and a tiny spot on the drivers door. Other than that the body's great.
so what do you guys think this car's worth? I was thinking around $1500 cash.
Thanks for your input/help, guys!
~BrandoN~
This car had a small fire after something apparently fell onto the turbo and started burning down the intake hose.
NEW Factory Remanufactured 7M-GTE Engine (just 7200miles)
Assembled with a COMETIC Multilayer Head Gasket
Torqued down 20 over (85 lbs/ft) with ARP head studs
New Gates Timing Belt
NEW Factory Remanufactured Toyota Turbo with larger housing (same compressor), a T63 Turbo (makes up to 18psi)!
Spec Racing Clutch with resurfaced flywheel
~BrandoN~
