Working on Making custom wire harness for 1jz gte into MKIII.
808steeze
28
Hawaii
I am Working on Making custom wire harness for 1jz gte into 87 supra Turbo and possibly non turbo MKIII. I am able to get brand new connectors and pins.
These are 3 connectors from the JZ harness that I need the opposite connector.
3 connectors from the 87T engine harness that I would need, and the e plug and I would need the opposite connector for the lead coming out of JZ ecu.
correct me if I am wrong, give me some advice, fresh harnesses coming soon.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
One of those 10pin connectors is a tns style and is used for gauges. If you want new, I'd advise buying a new type of connector with a currently available pin.
Sent from my ADR6400L using Tapatalk 2
