Woot! Engine carnage!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Well, after blowing out a head gasket from running 20psi on a 57trim, I finally tore down the block and took some photos of the carnage.
One BHG, one missing #2 ringland, one fried #2 piston, and one roasted #5 rod bearing = cool carnage pics! :D
PS: 56K will have time to order broadband, wait for it to be available, get it installed, and THEN they can view my pics.
VanSupra
Van,B.C.
SavageBoosterJack! Looks like you have a nice conversation piece/ashtray/paper weight/meat tenderizer for the cheaper cuts your teeth will be subject too due to the cost of this rebuild..Don't worry as I'm doing macaroni right now..lol..
VanSupra
Van,B.C.
GrimJack said:
Oh - I forgot to mention that I found the missing ring landing. It was kind of glued to the side of the crank, and feels like a rough beach sand with sharper edges.
Dave is that block and bottom end still salvagable?
J
JerzeySlowpra
Guest
all of that happened from a bhg?, how many miles were on that motor? salvagable?
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
I think #2 went a little lean, I have to get the injectors checked to see if one of them isn't firing quite as much.
I think the bottom end is still salvageable... it's not in bad shape, considering the look of the piston!
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
ill be the first to say it "that shit'll buff out"
time for some CP pistons, pauter rods and cryo-treatment ;) dont forget micropolishing the crank, resizing the rod ends and ARP hardware. also, id look to Swaintech for some ceramic coating for the crowns.
i still have you beat ;) you should see the #5 piston that came out of kellys/psifactors orignal 7M. it was melted all to hell. there was aluminum on the cylinder wall and the cylinder head.
nice kill regardless!!!
