Well, I just finished filling up my radiator with a 50/50 mix and i tried starting my car after I put the engine back together. I found a few misc leaks(drain cock on block was a tad loose and the FPR as well on the fuel rail). Noticing that fuel came out of the FPR both front and rear of the fuel rail. I'm going to say it's safe to assume she's gettings fuel into the fuel rail at least, beyond the injectors? I don't know how to tell at this point. I verified I have spark on cylinders 1 and 2. Ignition seems to be doing it's job very well. My fiance did notice the distributor rotor was not seated correctly and fixed it up(prior to testing cylinder 1 and 2 for spark). At this point I have no idea what to check next other than the diagnostics codes. I'm not even sure if the car has any and I'm searching the apartment for a paperclip now to rig it up and check. I'll be browsing the forums for any suggestions/advice any experienced 7M owner can give me at this time. I'd love to get her to crank asap, although she's not street legal yet, I need my garage to change my fiances oil and tune up before she heads to Dallas(3 hours away from home).
Thanks in Advance,
Eli
Thanks in Advance,
Eli
