wont start when hot
BoostnLoose
114
Canada
ok the problem is the car starts no problem when cold it fires right up but if i drive it hard or for longer then 15 minutes is doesnt want to fire. turns over but no fire. what could this be?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Well, it could be a few other things but you can't expect too much with little more than a "help, car broke" post.
Fuel pressure is supposed to stay up to prevent vapor formation after the engine is turned off. Depending on how long a hot engine sits (typically 30-45 minutes) a loss of rest pressure (Toyota calls it residual pressure but I'm using the Bosch term) will result in a hard/no start. The Fuel Pressure Up system also has a hand in preventing this but a loss of rest pressure will render it useless.
Bottom line is to check your fuel pressure either after jumpering the fuel pump on and then removing the jumper or checking it right after the engine is turned off. Pressure should hold at or above the value listed in the manual for the specified time.
BoostnLoose
114
Canada
thanks!
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
If it's not a loss of pressure test FC on the AFM while the AFM is hot. If there's a fracture in the traces or if the reeds are dirty or not make good contact that'll cut power to the fuel pump.
amichie
182
sYDNEy
Ditto. This happened on mine.
BoostnLoose
114
Canada
when u say test FC on the afm what do u mean?
CRE
Oct 24, 2005
3,485
Denver, CO
There's a switch in the AFM which will cut the power to the fuel pump if the vane is fully at rest (ie: there's no air entering the intake or the AFM (and as a result the switch) is disconnected).
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=94
From my dealing with the MAFT Pro I've found that on my car the pinout was incorrect. In my car E1 and FC are swapped from what's shown in the diagram. FC is pin 2. So check that you're testing the right line.
The TEWD shows FC as being pin #2:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=57
Walla Walla
4
Quebec
It could also be your starter connection... Mine was doing this all the time... Sometime i had to wait for an hour. When I Changed the motor (old one blew, crank bearing), for another 7mge, i kept the same starter, but I double checked all the starter wiring. Since then, never had that problem.
