Wondering About 7M Heads
iMod
136
Centralia/Chehalis
I was looking for info on 7M heads, and I came across Suprarx7nut's write up. I was reading along till I came across a part that said something about loosening the head bolts 3 turns and in order or it might end up warping the head....Yea anyways that's not how I took off my head. I'm guessing that it's a sure thing that my head is warped. I planned on taking it to a local shop to check if it was warped anyways.
Anyways I was just wondering what are some other options if it is warped. Is there anywhere I could get a new head or a head that's definitely not warped. I'd go to a junk yard but there's no guarentee that a head from there wouldn't be warped as well right?
AJ'S 88NA
2,419
Florida
You need to take it to the machine shop and let them check it, if it's not to bad they can surface it. If you need another, what Dumbo suggested would be a quick check to see if it's within limits.
