wiseco piston to bore clearance
brad92t
186
Lexington, KY
www.haxors.us
I just got my wiseco pistons in today! Shiny!
So anyway this sheet that came with them says 0.0025 for the piston to bore clearance.. well that seems a little tight for a forged piston to me! I searched around and I see no real solid info for these pistons. Some recommendations between .004 and .005.
remembering that they are coated, what have you guys been running on your wisecos?
gixxer750
2jzget comingsoon!
Mississippi
I'm running the recomended slack. I love it, no pistons slap...even cold. It doesn't set the knock sensors off, and the engine just sounds good. I've run 22 psi of boost and haven't had a problem yet.
quake
toyota tech
Apr 13, 2005
619
r.i.
the coating is half a thou so i would set it for 3 and a half thou when the coating wears away you will have 4thou. 2618 needs room to expand or u run risk of scuffing the pistons besides what happens when u build the thing and want another 100rwhp in a year?
