TOYOTA
MODEL YEAR(S)
SUPRA 1987 -1993
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) and WHITE/RED (+) IGNITION
SWITCH HARNESS
STARTER BLACK/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 PINK/BLUE (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) PINK (-) @ STEERING COLUMN HARNESS
PARKING LIGHTS ( + ) GREEN (+) IN DRIVERS KICK PANEL
POWER LOCK GREEN/YELLOW (TYPE B) IN EITHER KICK PANEL
POWER UNLOCK BLUE/BLACK (TYPE B) IN EITHER KICK PANEL
DOOR TRIGGER RED/WHITE (-) IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION USE DOOR TRIGGER
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLUE/RED (-) @ STEERING COLUMN HARNESS
TACH BLACK (-) @ CHECK CONNECTOR, See NOTE *1
WAIT TO START LIGHT N/A
BRAKE GREEN/WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM PURPLE/YELLOW (-) IN EITHER KICK PANEL
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 the CHECK Connector, is located at the FRONT of the DRIVERS Strut Tower, it is a Small Rectanglar plastic box. It is either BLACK, GRAY or GREEN and is marked DIAGNOSTIC.
