I have a broken rear knock sensor. i was wondering if I could temporarily splice the rear knock sensor wire into the front one.
RIPDOTCOM said:I have a broken rear knock sensor. i was wondering if I could temporarily splice the rear knock sensor wire into the front one.
PorterzSupra said:You sure can, just dont boost high (like way over stock boost) untill you get it fixed
lagged said:bad advice anyone?
PorterzSupra said:((shakes head)) there is NO reason for a stock or slightly modified turbo engine to knock in the first place. I am running a high compression NA with 1 knock sensor with a large turbo, I wouldent give advice if I dident know from personal experience! It takes ALOT of boost to get the 7MGTE to knock and if the pre knock got bad enough the second knock sensor would pick it up way before the point of engine damage.
supra90turbo said:mk3 owners, cheap? what?
Joel W. said:Thi sthre adist ofre akin gfun nnyl ol
