Wiring harness
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
Are there different harnesses for each year and trans style? I am asking cause I have a 88 auto and found a 89 manual. Will it interchange or will it not.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
It will NOT work. Contrary to popular belief, there are many harnesses over the years. Unless you are good with wiring, and ready to make things work, you should get the proper year harness. You can use an auto harness in a 5-speed car, but there are differences between the years. 86-88's are pretty interchangeable I believe, but there are changes between 88-89 and 89-90. I'm not sure, but I believe it changed again between 90-91 then stayed the same for 92. There is a sticker near the ECU end of the harness that has the part number on it. You should try to match it.
Edit********I re-read your post. There are actually two different 89 harnesses at least. Early 89's had the yellow plug harness like the 88. If the 89 harness is yellow plugged, it should work.
VooDoo
Mar 20, 2008
342
Valdosta ,Ga
I have a turbo.
The deal is I bought a Maft Pro with it already wired up. I was hoping i could just pull mine and put this one in. SO I will wire it up to mine. I will just need to get a install and users manual.
shiftysupra
180
Tucson, AZ
if you use the search button up at the top, there's a post that shows you EXACTLY how to wire the unit to your current harness... even has diagram with colored wires and everything....
