Wiring harness
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
I have a jza70 wiring harness, do i need any part of my 7mgte harness? or can i sell my 7m harness. i know i have to extend the 1j harness, but i cant figure out if i need some of the body plugs.
sorry if this has already been answered
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
I'm sure this has been covered alot, but yes you need the body connectors, there are four by the ecu. not the ones going to the ecu.
makaveli913
1jz and lovin it
Nov 20, 2007
135
Pueblo Co
i need info on this too. what do you mean not the ones that go into the ecu? So i plug the jza70 plugs into the 1jz ecu?? where do the 7m connectors plug into?
JonoTurbo
Going for broke
CT
The plugs you will need are for the dash harness, the ECU plugs are not touched. You don't actually need your 7m harness plugs, it just makes life easier. I was able to make all of the plugs from other toyota plugs. If you have a 90+ car, one of the plugs on the 1jz harness is the same as well.
