wiring direction
ryostyle
60
Sacramento, CA
Putting my car back together and am having a problem connecting all the harness connections. My question is, am i supposed to route the harness for the injectors from under the intake manifold or on top of the manifold. Everything is connected but the starter solenoid wire won't reach.....
The harness goes on top of the lower intake manifold. Should have plenty of room to fit and everything should just fall in place.
Sure you didnt move it too far forward? There are certain parts of the harness that slide through the hole in the lower intake manifold.
The starter wire, the egr vsv, abs, and reverse lights should all feed through the rear hole on the intake manifold.
