wiring cut
nestor bouboule
12
Cherbourg
Hello everyone is still the French boring.
So I do not know how to connect the son who are cut off. I have traveled the forum throughout and I found nothing I did or failed to translate correctly.
Help me please, because I'm lost
jnianekeo
128
Mill Creek, WA
mine were also cut. They go to your Igniter and Main wire engine harness... If you are converting them over to the MA70 wiring, some of those wires go to the C1 plug, alternator plug, and one wire goes to the A/C...
Is this a JZZ30 motor? JZA70? the wiring colors are different for the igniter.
Give us a little more information about your swap... keeping old haress? converting? using the harness off the motor?
Satan
Tampa
Your only other option is to trace each one and determine what's at the opposite end.
