Wiring a Soarer 1jz, into a MKIII '92
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Okay I am not sure if this will get stickied or not but here it goes.
Last year sometime I bought a 1jz from a Soarer with a Automatic harness.
I spent roughly 60 + hours making this harness fit for a MKIII with a 5-speed in it.
Each pin was identified with a DVOM to ensure they were going to the correct placement.
I made a website, ( Freewebs ) I know, but it was free and I wanted to place my work somewhere.
Here it is.
www.freewebs.com/1jz-gte
If anyone needs helps swapping a 1jz into there car, even for pre '89 let me know. I have the wiring configurations down, but remember it is totally different for pre-'89's, so if you would like some guidance let me know, thanks.
Pictures are provided use them!
Hope this helps some of you.
-Teal
odomd
computer illiterate
Jan 11, 2006
130
nj
Wow 60hrs you could of saved alot of time if you searched alittle and used the post I let afonz put up.
Here it is.
-Teal
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
staticpage;1302197 said:
yep used your site to do my swap thanks man
Awesome to hear, did all the directions go well, did you run into any problems?
Thanks,
-Teal
What I am going to do next is take a '89 Auto harness and write down what every color is, and what every color on each plug is. Then people will know exactly what these pins go to.
