Windshield Install - Who's Done it before?
KINGPIN33
183
Canada
So I have to replace my windshield. I would take it to someone to do, BUT theres som rust around the windshield that needs to take care of, so I will do that part.
I've read the TSRM its got all this whacky stuff you need like primers etc. I thought you just need the Urethane that comes in a tube such as this one:
http://cgi.ebay.com/ebaymotors/8609-...spagenameZWD1V
Also, how hard is it to install the clips that attach the moulding around the windshield? There seems to be 3 different types of them around the whole thing.
Any advice etc?
Thanks.
chopstickz
227
SoCal
i had my windshield change 2 months ago and it took the guy 15 minutes. theres 2-3 screws where you have to pop up the hood.and the window trim i think it just pops out.
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
You have to remove the black trim under the windshield and undo the screws behind that. After that I have no clue.
I can tell you from experience that it wont pop out if you pry on it with a screw driver just leave you with a very nasty crack.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
its all urethane under the windsheild. you need To remove al lthe lower trim and i believe it pops off. Im not too sure thoug hand i woudl liek yto know because i want to fix the stupid rust starting under it -_-
There's a 2 handed tool with a blade and a cable handle you use to slice through the urethane glue strip that bonds the glass to the body.
(after you've removed all of the trim parts)
Jetfixr757
Sleeper
Cocoa, Florida
10 mins and the glass is loose with this one.
Jet
