Windows rattle; felt pad info needed
Satan
Tampa
I've got this common issue (I had it in my previous Supras anyways). The windows rattle from side-to-side. The felt pad (or whatever) is wore out and the metal behind it, scratches your tint/window.... You can see the path I outlined in the 1st pic and the wore out spot, where the metal really does it's damage when the window's down (2nd pic)....
I posted on SF, but need a quick answer (to finish retint tomorrow). Anywasy, you can see how the guide that brings the windows down, will just damage my new tint as well. Partnumbers and/or specific details to fix would be very appreciated.
Satan
Tampa
I've had the door panels off more times than I care to remember... I guess I'll pull it off and see what I can find this evening... get more pics, etc.
Satan
Tampa
It helps.... I guess it's called a door glass stopper... There are 2 of 'em in the door (inside) and opposite side of window is a piece of felt also, attached to the top trim on the door.... on mine, the felt is pretty flat/worn. What should I do, just buy some felt from the fabric store and glue it on over this mess? Pics...
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
very artsitic with the black and white :D
Satan
Tampa
Hee hee... Actually that the 2nd time that the camera did that. Once with the interior pics (at nite) and now this... I selected a "close-up" scene selection, with flash. The door is black, but the floor is gray with different-colored specs.
I wish I could do it on purpose ;-)
Any ideas... should I get some felt and just hot-glue it over this old stuff?
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
Well, you could buy this from Jay marks, brand new for $10 each, 2 per door.
67231-20020 for RH
67232-20020 for LH
that is... if they have them available or can reproduce new ones at Toyota of Japan. and if they Can make them again, youre lookin at a 2 month wait.
ive got a used set if you want them...
Satan
Tampa
I'd rather not use used ones, since the same thing will happen sooner. I do have some new ones on the way from Toyota...s/b here early next week. Thanx!!
