Windows Media Player
faithless88
Utah
When ever I try and play a file wheter it be music video I get the erroe code C00D11B1. But I also try real player no luck. But another video program I have runs it just fine and itunes also works. I'm at my witts end about this any help would be nice. Also 2months ago this happened I'm using 11 now it does not work. But before the problem was also using 11 and had no preoblems.
faithless88
Utah
I have tried other but nothing works so far. Guess I will go and try some others. Mainly trying to fix it for a 10yr old brother and 12yr old sister that both really don't know how to use computers.
faithless88
Utah
What are the names on it. I was looking through microsofts page and found out that alot of people have this problem but no anwsers and microsoft gives shit for anwsers.
TurboWarrior
Canada
Did you try this?
1. Exit all programs.
2. For Windows XP, click Start, click Run, type regedit, and then click OK.
For Windows Vista, click Start, type regedit in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for confirmation, type the password or click Continue.
3. Locate and then click the following key:
HkeyLocalMachine\Software\Microsoft\Windows\CurrentVersion\Audio
4. Locate and double-click DisableProtectedAudioDG.
Note If this key does not appear, you cannot complete these steps.
Under Value data, change the value from 1 to 0.
5. Restart the computer.
romaniello
94
Sanford, FL
faithless88 said:
I don't even have the file for audio, also need to know the binary for the key which I don't.
Are you sure about that?
Anyway, the best solution will probably be to uninstall WMP 11 and revert back to WMP 10. That's what I did when I first used its UI.
