will this turbo work for me?
robbo185
693
Chicago
a bic ddp has the same flange as stock elbow...so i dont see why it wouldnt....askt the question in the horsepower freaks section here and you will get a definite answer
89turboguy
196
Denver, Colorado
rakkasan said:
IIRC, no, it won't bolt up to a BIC DPP. I think randy makes on specifically for the SP turbos.
im pretty sure rakkasan is correct. i dont think it will bolt up with the ddp. but the regular bic dp will bolt up.
NickSupra
179
tn
The DP will bolt up, but you will have a major exhaust leak. The divider wall for the wastegates are different.
MKIIINA
Destroyer of Turbos
Plano, TX
/\ hes right. i tested it out with a local guy for a possible swap one time and it wont work. the dividers are slightly different but enough to make a difference! i also decided that i didnt like the idea of having a loud ass exhaust everytime i got on it with the open wastegate so i went back to my regular BIC dp which works fine for both the sp61gt and the stock ct26. maybe next time ill get the rerouted sp61 version ddp...well see
