will this create a pretty rough stumbling idle?
pingerpar
Wanting another supra
Aug 14, 2006
34
St Charles
Will these valve clearances create a stumbling idle when engine is hot? When cold engine seems to run fine.....That led me to valve clearances, i set up the cps correctly according to the shop manual, not sure if that is correct. Should i look at something else? Any Takers? (Exh .20-.30mm, Int .15-.25mm is specification)
Exhaust
1. .34mm
2. .34mm
3. .29mm
4. .34mm
5. .29mm
6. .33mm
7. .23mm
8. .38mm
9. .24mm
10. .31mm
11. .33mm
12. .28mm
Intake
1. .13mm
2. .29mm
3. .21mm
4. .28mm
5. .20mm
6. .23mm
7. .23mm
8. .24mm
9. .26mm
10. .18mm
11. .18mm
12. .13mm
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
it shouldn't..
would probaly make some valve noise.
check your vacume it should be really close to 20inmh
check for cracks in accordian hose, and for clogged vac lines.
also that there is no debree in the idle speed control motor intake tube.
pingerpar
Aug 14, 2006
34
St Charles
i will try cleaning out the isc, i think all of my hoses are ok, but its cheap so i might just get all new ones, i had a code for the cps a few weeks ago, the wire had a few cracks on it inside of the cam sensor, i attempted to fix it before with a little shrink wrap but i dont know if it helped, ill be able to check vacuum next weekend, compression is all good, any other suggestions guys before i dig into it again?
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
inspect your cps further. sounds like it may have a high resistence problem when it's hot. that will cause a bad idle byu not sparking the plug's correctly.
i heard it is only really used at start up. (so says my instructor, but i belive our's control spark to a point.
