will they fit?
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
hhmmmm......maybe you can do lug conversions like other cars. I don't know about the supra though...why don't you look for a set for the 5x114 bolt pattern.?
supra88gr
110
s dub
i love these wheels i have a pair for my VW and i think they would look good on my supra. what are my options?
shaeff
Kurt is FTMFW x2!!!!
10
Around
Just look for wheels with the correct lug spacing, then they will "fit". If it doesn't have 5x114.3 spacing, then they will not bolt on, and will require much more work to get right, if at all possible.
There's a guy here who got BMW rims to fit his car, not sure if he did a lug conversion or what, but BMW's use the same bolt pattern as VW's.
Wiisass
Looking other places than VW vortex would probably be a good start if you're looking for wheels that fit.
IF you really need to buy wheels that are not the right bolt pattern, you can use an adapter to make them fit. But remember the adapter will add about 1".
So if you still want to do that, subtract 1" from the offset and get the new offset and then go in the wheel fitment thread and see if the width and offset and tire size combination will work with your car.
If it still works with the 1" spacer/adapter, then do it if you really want.
I would suggest looking other places for wheels. The first set is ugly and the second set looks like 8 million other sets that are available all over the place in the right bolt pattern and size.
Second set looks a lot like work equips...
But I agree, not looking in the "VWvortex Forums 5x112 Classifieds" section would be a goos start as you know every wheel in there WON'T fit...
