Compression. Well the plan is to bore my 7M-GTE .40 over and make the head be able to have a 2.0mm thick head gasket... I found it it raises the compression. I also know that turbo engines have lower compression because the turbo is like a compressor and when boost hits compression raises. My dilemma is I think by doing what I want will raise compression so much that I might break something... My question is can I do all this without hurting the engine.... Actually I have no idea what I am saying I need some help.
Heres links to what i want is there anything else I need to make this work?
Head Gasket
http://www.suprasport.com/HKS-MHG-7M_p_261-96.html
Pistons
http://www.suprasport.com/CP-Pistons-0040-over_p_63-767.html
Cam Gears
http://www.suprasport.com/AEM-True-Time-Cam-Gears_p_63-324.html
valve springs
http://www.suprasport.com/Dual-Spring-Valve-Springs_p_63-768.html
Of course i will get stronger rods(stock length) and probaly a stock stronger crankshaft because mine is worn out.
Stage 2 cams
http://www.jscspeed.com/mk3/engine/bc_cams.htm
I have an idea on what will work for exhuast and turbo and injectors and fuel pump and AFM and intercooler.
yeah I know its alot of stuff you are probably going to ask dude what the heck do you even have the money for it. I say if you have nothing nice to say please don't say it. Negative comments suck but If you can help me with the knowledge I would very much appreciate it. I would like to make some new friends here and not enemies. Thank you so much!
Head Gasket
Pistons
Cam Gears
valve springs
Stage 2 cams
