will not crank
CrazySupra
60
North alabama
Pulled car or to wash it and now will not crank. Only one small click from passenger side. I thought it might be safety switch but I can hear the fuel pump on and while holding switch and pull in reverse it goes off. Any help from you guys would be great. I have senior pictures tomorrow and car show saturday and need car running. Thanks
supra1jz
284
Auburn, Georgia, United States
Have you tried to have someone jump you off to see if it starts and if it does that way then you are starting to have what most supra owners have the wiring to the starter relay I had this problem before and when I jump off my car it would start then I rewired my starter relay and never had the problem again.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
CrazySupra;1958922 said:
Yes I have been troubleshooting it. I'm sure its a common problem that somebody already had. Thought supra guys help each other.
I hate to state the obvious but electrical problems are not easily resolved from afar.
CrazySupra;1958927 said:
I was thinking there was a relay on that side.
There are two. Well, more than two but only two operate when you're trying to start the engine.
supra1jz;1958938 said:
... I had this problem before and *when I jump off my car it would start*...
Pretty good clue what the problem was right there but you either ignored it or didn't realize its significance.
Just take some wire and put one end on the positive side of the battery and the other in place of the little wire on the starter. If it cranks when you do that that will tell you whether your starter is bad or not.
Also its pretty easy to test the relay vs just throwing parts at it.
8,894
Yes. Bad batteries are common after extended usage. And discharged batteries are common with bad charging systems or leaving things on in the car with the car off.
Do you go to work for free? That isn't rhetorical.
