Will my Supra run OK......for now?
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
Hi.
Ok
First is a list of my mods.
Cometic HG
APR Studs
K&N Cone Intake
2.5"stainlees steel downpipe to 2.5"exhaust
Just installed
Ported and polished exhaust manifold and turbo elbow
Upgraded 60-1 Ct-26.
Will my car run ok? What other mods should I be looking into. I know a Good Tuning would benifit but I'm short on cash for now.
Future purchase would most likely be
SAFC
Boost controller
Is there something that will control boost and air fuel ratio?
full 3"exhaust
Do I need a lexus afm/550's?
Thanks
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
get a manual boost controller from DR jonez... there affordable and ez tpo use.
i cant imagine how your idle and car would run, but im guessing it will be pretty rough.
im guessing your going to be boost really low on that 60-1 since u have no tuning capabilities.
it would be nice if u go to the lex afm/ 550 route, u dont have to but i'd suggest u do.
have u cleaned out your injectors at all or flow tested??
look into a new feul pump, AFPR, and invest in a wideband
lagged
1991 1JZ
new rochelle
why will his idle be rough? it should idle fine.
really though the FIRSt thing you should do is the fuel system, and get a wideband.
at the VERY LEAST replace your 20 year old fuel pump.
JB91389
Jun 22, 2006
698
Ottawa
injectors are clean and tested
i meant to add a fuel pump to the list i'll get....walbro 255 is good?
wideband? Sorry for the newbie question....whats is it and what does it do?
JB91389
Jun 22, 2006
698
Ottawa
thx s383.
I'l definately be getting one...just not yet...anyways....my car wont come uot until april/may so I got some time to save up...
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
If you can go with something else other then the LEX AFM like the MAFT pro and a mapecu,
either way you need bigger injectors or your could do it the cheap way and do aditonal injectors and control that with an AIC.
