will it
JNasty
i drive fast cars (supra)
Jun 25, 2005
358
Jacksonville fl
ok well i did a turbo swap in to a non turbo body i thought that i fixed all the vacume hoses but maybe not i did away with the charcole canester would that have anything to do with it
and is ic pipeing considered vacume
MKIIINA
Destroyer of Turbos
Plano, TX
ok chief it usually is one bump every 24 hrs.... not 3.... second im doubting you have checked your ISC and tps yet. to see how to test them check the TSRM. its online and easy to read. IC is not really considered vaccum to me as its part of the intake system. check the TSRM for a full vaccum diagram.
JNasty
Jun 25, 2005
358
Jacksonville fl
ok chief what the hell is tsrm
JNasty
Jun 25, 2005
358
Jacksonville fl
oh yeah and learn how to count 2 not 3
MKIIINA
Destroyer of Turbos
Plano, TX
man you are lazy.... ok the TSRM is the Toyota Service and Repair Manual. please search some.
ps: it was 2hrs 29 mins but i rounded up to give you the benefit of the doubt. your first bump was a shade over an hour. :)
supraman7mgte
Shut up,bitch!!
Sunny California
a bad isc would make your car idle low,right? its kinda like a stepping motor,that you can hear when you shut the car off,its near the throttle body on the intake,and goes "tika-tika-tika-tika" when the motor is turned off
