Will a MK4 radiator pipe fit on 7mge?
SupraMario
I think it was the google
The Farm
Looks like the rad. inlet side is going to be to long, but like late said u can always cut it down.
group a supra
SPAWNING AN INTERCEPTOR
yep and the need to weld a lip on it or do something so it grips the clips and avoids the top hose coming of please only give advice on these subjects if you give a full explanation as non engine minded people will wnd up with no head gasket
so the correct answer would buy the cheap one cut it to fit and have the end flaired out so it grips the clips costin nearly as much as the done one ;) but with some messing
1TuffSupra
Sho' Nuff
Jul 11, 2005
500
Raleigh, North Carolina, United States
someone on the forum replaced their upper rad pipe with some pipe they found in home depot or lowes. IIRC, he said he spent like 10-15 and it looked very very similar to the cooleze pipes made for our cars in the pics he provided. Hopefully he will pop up and post, but it is definitely worth it to ride out to your local store and look around.
supramacist
1,501
The Grassy Knole
I get alot done with my car thanks to lowes, honestly. If you are afraid of deaking with the bhg, you should stick with mkIII parts. IMO. But outstanding it is to try new things. Use the force, LOL.
