I'm using a 1jz ffim. The 1jz iscv uses the same plug as the 7M's. But will it funtion properly?
MarkIII4Me Project OVERKILL!!! Apr 10, 2005 1,249 2 38 Charleston, SC Apr 18, 2011 #1 I'm using a 1jz ffim. The 1jz iscv uses the same plug as the 7M's. But will it funtion properly?
M MightyAl New Member Jun 5, 2005 293 0 0 Chesterfield, MO Apr 21, 2011 #3 It should be the exact same thing. If it is a 6 wire stepper IAC then it will operate correctly.
C CT26smoker Banned May 25, 2010 223 0 0 Houston Apr 21, 2011 #4 Makes sense. I was hoping that a remote mount ISCV from a 4AG would work, and have one set asside for an upcoming project.
MarkIII4Me Project OVERKILL!!! Apr 10, 2005 1,249 2 38 Charleston, SC Apr 23, 2011 #5 MightyAl;1702121 said: It should be the exact same thing. If it is a 6 wire stepper IAC then it will operate correctly. Click to expand... It is as far as I know. So I guess my problem must be stemming from the 1J/2J TPS sensor. Dammit!
