Will 18X8.5-114.3 30mm fit?
j_magers
Honolulu, HI
Trying to find out if these will fit my 88':
18X9.5-114.3 38mm for the rear
and
18X8.5-114.3 30mm for the front?
Is there any kind of spacer that would make it fit.
Pretty sure the rear is perfect, not sure on the front.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
They should fit fine. Stock is 16x7 with 38mm. So, you add 1.2 inch to the stock wheel to the fender and add 7mm too and that's how close it will come to the fender. I think it will look perfect. Get pictures when you get it.
PIONEER
Wallet Wide Open
Raleigh, Nc
I'm running
18x9 front +12 255/40/18
18x10 rear +24 275/35/18
Not to mislead you but I did pull the fenders in the front. maybe with 235 tires you will have enough negative camber to push the wheel inwords in the fenders. I rolled the rear fenders as well. 275 is tooo much with this offset and the width of rim. maybe 265 is the way to go.
More Pictures can be found here
j_magers
Honolulu, HI
The math comes out to be:
Stock: 16 X 7 with 38mm = 215.8mm = 8.49 inches /2 = 4.245 inches
New: 18 X 8.5 with 30mm = 245.9mm = 9.68 inches /2 = 4. 84 inches
so its really only .595 inches bigger on each side,
yeah I think they will be just about perfect also.
thanks had to put the junior college education to work
anyone disagree with the math
bo3232000
Lurking in the dark
Jul 22, 2005
57
Cumming,Georgia
I just purchased a set of ruff racing 277's they are 18x9.5 30mm,and 18x8.5 30mm.. They fit like the factory designed them..You may have to roll the fenders with the 38mm you have but 30mm ft and rear fit like a glove......:icon_razz
Hope this helps:evil2:
