Wikipedia credibility?
Do you trust WIKIPEDIA?
  • Total voters
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
So I just realized when I need info on just about anything at all, the first place I look is wikipedia. In school they always tell us that wiki is a horrible place to look for facts as some of it can be edited by users.
Now I'm fully aware of the editing and such, but I would venture a guess and say that 90% of the info there is true. I would never trust it on anything important, but for most facts it seems great.
After all, it's not like the rest of the internet is filled with 100% correct info...
What do you guys think about WIKIPEDIA's credibility?
Need another selection of "yes, but I confirm all sources"
Wikipedia is great, just pay attention to when it says that it doesn't have an sources to back up the info. If there are sources go to them.
I always try and confirm any info through other sources, and I even do this with more reputable sources...
OneJoeZee
Retired Post Whore
aboard the Argama
Check the references before you use anything too important as "fact" or "evidence."
In any case, it's better to cite the references instead of the wikipedia page.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Wikipedia is pretty much dead on as long as you don't look at the controversy subjects. Even those are right at least 50% of the time. You can get a really good idea of the controversy level on any page by looking at the revision history.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
I've seen way too much information be off or plain wrong on Wikipedia. I've even seen my own information that I posted get edited by someone to something that is incorrect.
It is neat and has a lot of interesting information, but I don't trust anything on there without a secondary (reliable) source.
Jeff
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Sounds like most of you stand about where I do.
I usually use it for curiosities and useless info so I don't *generally* try to source it elsewhere. Although if I need some solid info or something that I may actually use then I'll certainly find more sources to back the point.
What I really like about it though is that you can type virtually ANYTHING into google, add "wiki" and you'll get to the wiki page which will first give you a broad overview of the topic and then proceed with more detail.
Doward
4,245
Alachua, FL
Like ANY 'source' of information, check into their sources, as well.
Since there's not a "Trust it, as long as the sources check out" option, I put 'mostly'
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
+1 for verifying the source and Doward's comments. As a starting point it is perfect search engine of sorts, but that's as far as I would trust it without verifying the sources.
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
suprarx7nut;928508 said:
Do you know of any online, free encyclopedia's that are more trustworthy AND as expansive as Wiki?
If so, let me know! :)
No, but you can use encyclopedia.com or brittanica.com. They may net be as expansive, but all of their info is gone over and approved before it is posted.
