wideband o2 tools
clifftrail
128
Abq
There are alot of people using this product and not on just Supra's. I've got it on mine and it does what it's advertised to do. I log RPM and A/F, hoping to include boost in there sometime when I get around to it. Good product.
clifftrail
128
Abq
You can't change the A/F with the WB. It only lets you see what the A/F is doing. Your going to need some type of fuel piggy back controller to tune the A/F. Not too sure about the MAF-T but I don't believe it lets you fine tune the fuel curve. Just make some initial settings based upon the type of injectors your running. However the MAFT-PRO does appear to be alot more flexible and allow you to do this. There are several threads that talk to it, do a search and they will pop up.
