wideband bung on ceramic dp
san supra
833
san antonio
i have a ceramic coated coolez ct26 turbo back downpipe
best place to weld the wideband bung and any type of bung i should get? (i dont have a wideband and i dont know what i should buy)
any problems welding around ceramic coating with a mig?
should i weld it myself or is this a pro job? (i can weld, just not pretty)
the downpipe is off the car
thank you for any help
figgie
Twin Cities, Minnesot-ah
In reality, it depends mostly on the electronics more so than the max operating temprature of the wide band sensor.
As a example,
LSU 4.2
Exhaust gas temperature range (operating) 930 °C
Exhaust gas temperature range (max.) < 1,030 °C
Hexagon temperature < 570 °C
To put it nicely, if the wideband sensor itself is seeing 930 celsius (folks that is 1706 degree Farenheit). The last thing you should be worrying about is the wideband!.
The real kicker is the Hexagon temp which is not as high as the sensor itself.
For that you need a heatsink,
http://www.innovatemotorsports.com/xcart/product.php?productid=16148&cat=250&page=1
Also a custom copper heatsink works best.
san supra
833
san antonio
As a example,
LSU 4.2
well my motor is not going to reach melting temps so do i still need the bung extender?
will the extender make my wideband to cold and cause it to read wrong?
i thought i could just weld in a bung and then screw in a wideband later and that was it!
ANY PICTURES OF WIDEBAND INSTALLED?
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
The driftmotion bung is just like any other screw in O2 bung so it should work for narrow or wideband o2's. The most common length I've heard is 18" minimum away from the turbo.
You're going to have to grind the ceramic coating away from the hole to weld the bung on. I would drill your hole, put tape around how far you want to grind the ceramic away and do that (a wire brush on a drill or angle grinder with sandpaper should work fine) then remove the tape and weld the bung on.
san supra
833
san antonio
My dp is off the car and i didnt mark the best place to weld the bung. I know 2ft down but at what angle?
pictures of some widebands installed would help a bunch. I dont want it to hit anything when i install the sensor.
thanks
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Oh haha..Well you might just have to wait until the motor is back in. I wouldn't chance just trying to eyeball the fitment. More than likely you'll install it and it'll interfere with something.
san supra
833
san antonio
1 problem. My dp is turbo (ct26) back and i cant get to the inner bottom nut when the motor is in.
there has to be someone here that can tell me a measurement like 18in down and 3/4in off the center line to the inside of the car or something.
Supraflymk3
Supraman
Dec 17, 2005
272
Neenah, Wisconsin, United States
You should just wait until its back in the car, will be alot easier for marking a safe spot and theres no way that you're not able to get the downpipe off with the engine in the car. Downpipes are bolt on parts they shouldn't require you to pull your whole engine just to put it on. Either your lacking tools or your not using them to your advantage. As for buying a bung to weld on why don't you just order a wideband kit like the innovate lc1 very good wideband and very inexpensive. Most wideband kits will come with a bung that way you won't have wasted your money on one before you even buy a wideband. Just my two cents, take it or leave it.
san supra
833
san antonio
thank you for your reply
i just dont have the money right now (in between jobs) but the bung will not be wasted because i plan on welding the extra one on my truck.
the dp doesnt require you to pull your engine but its easier to drop it in with the motor, there has to be a general area that a wideband would fit.
S.A. supra
2,405
Buda, Texas
I say put the engine back in and Mark it. then drop the down pipe out the bottom, and weld it on.
I can take a pic of my setup. It's a little different.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
As a example,
LSU 4.2
I run one of these heatsinks, and it's working great. My first bosch O2 got cooked and the new one is fine with the heatsink.
image.php
