Im not for sure if anyone has ever seen or heard of this Problem.
Im assuming that a Normal O2 sensor and Wideband sensor would read in the Rich Area when you first start you car up in the mornings and Once it warms up, it starts reading in the Mid Range ie 14.4 through 15.0
Mine and Ive never had this problem until I installed the VPC setup that I have... When I start the car up in the Mornings it goes to the lean side and Stays there until the Engine starts to warm up. Then it moves up to the Mid Range Area.... I dont like it and Im wondering is this a Sign of a O2 sensor or Wideband Sensor going Bad. I cant drive the car right now because as soon as I give it gas, It Automatically drops to Lean (17.0) or off the Scale and it sputters it ass off.
Any Help.
Im running the AEM Wideband and a 3 Wire O2 sensor. Both are Installed wideband Farthest from the Turbo.
Robert
Any Help.
Robert
