Wide Band..UEGO
LEGNA
80
CT
Very simple whats the best place to install the sensor the elbow or the down pipe..thanks
mixmastermatt
Former Nissan Junkie
Mar 30, 2006
124
Taftville, CT
The elbow and downpipe are both after the turbine. Angel, I'd put it in the downpipe about 6" from the flange that connects to the elbow, that way it'll cut down on possibility of a false reading if you get a leak at any of the flanges on the elbow..
Red Dragon
Keep That on the Down Low
Jan 5, 2006
318
Austin, TX
I put mine further down to keep it away from the searing EGT's. The manual IIRC says a minimum of 36" from turbo, so thats what I did, its up in the tranny tunnel. search my posts, somewhere I have pics with my set up installed on the car.
Some people feel you don't have to do this and install it right near the turbo, but whatever, do what you want, I personally didn't wanna fry it. (the stock o2 is MUCH more heat resistant, its a differnt technologu altogether, so its not "OK" cause the stock one is there)
edit: found the post
http://www.supramania.com/forums/showthread.php?t=14514
