Why Wont It Start?
MA70witBoost
Registered Drifter
Ok, I just got my supra. It was running good for the first week or so, motor is perfect, no oil leaks or anything. Has a boost leak in the intercooler piping, needs a new wiring harness, the wires to the cam position sensor need to be re-done. most of the wires are cut there. The alarm used to activate now it doesn't for some strange reason. I let my boy david hear it turn over and he thinks its lacking fuel. I dont know this car as well as i know a 240 so i have no clue as to where the fuel filter is. If i did id disconnect the fuel line from the filter and turn it over to see if any fuel comes out. he also told me that if the alarm isn't working that the car wont start. anyone have any idea's? It has a steady turn over at first and then it speeds up like its trying to turn on... not sure. Air to fuel reads stoich when turning over and lean when not. the boost gauge also slightly moves down to vacuum when turning over. :1zhelp: please.
jester1341
topless and blown
Western Maryland
i'm with MDC, get a good solder on there!!
and also the alarm cuts the starter relay so if your starter is spining it's not the alarm ;)[if it is the alarm get out lock the pass. side door and unlock it(from the out side both times)]
john
MA70witBoost
Registered Drifter
yeah, the cps is faulty anyways, im waiting for the new one to come in and im planning on soldering it as a temporary fix. I'll be getting a new wiring harness for it I just dont wanna wait 2 more months without it running. Also, the alarm use to arm itself... I didn't mess with any of the electricals on the car it just wont arm anymore. I thought it was lock the doors, hold the door handle up when i close it and the alarm would arm but nothing now. Whats up with this? I hear theres a sequence for this. anyone know of it?
jester1341
topless and blown
Western Maryland
give jeff a hand i didn't even notice we were in the wrong section.....man, thats why i have no athority....
ahhh...sequence...all i do is lock the door with the key when i get out sec. light comes on and it is armed
john
