i have tried countless times to get these injector o rings to seal and i can not get them to! can some one tell me a trick or two to get them to seal up? thanks so much.
i have tried to leave them all loose and line it up and start with the center bolt and as it stats to get tight it just moves them off and i can see a gap.
then tried to hold it to were its sealed and tighten the right side and left side at the same time with no luck either.
