why must the turbo oil feed/return be 12/6 o clock?.....
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
when these guys haven't got it set up straight up/down?
in order to get my turbo to sit perfectly vertical on my manifold i have to redo my oil drain AGAIN!!! and i spent some pretty good $$ getting all the flanges and fittings for the drain
mine sits fairly similar to the first two pics below
tissimo
Stock is boring :(
Melbourne, FL
Itll work, but oil might not drain from the turbo causing it to burn up in the turbo which can lead to other problems..
mkIIIman089
Ohio
They should be straight up and down just to insure the oil is draining out instead of flooding the "seal" and having it leak out if there isn't enough shaft speed.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
The drain must be no more than 10 deg off center. The turbo oil drains off of gravity, with the PCV vacuum helping it along.
Any thing more than 10 deg, and the seals will leak causing smoking and turbo failure on down the road.
