Ok i discovered that white smote intermitenly starts pouring out of the exhaust, and them goes away and starts again a minute later. All this was after a toyota factory gasket, rebuilt head and APR's at 85 ft lbs. So I thought it was the turbo. I rerouted the turbo coolant lines and bypassed the turbo and it still smokes out of the exhaust. I did a compression test and it was all fine. It smokes so much I think the neighbors are worried!!:aigo: anyway the motor runs fine and idles fine and accelerates fine. I finally tore apart my motor, and discovered.....NOTHING. HG fine, head fine, no noticeable problems, no cracks in the cylinders walls, no noticeable steem from any cylindar combustion chamber. I am totally dumbfounded the only other thing I can think of is the throtle body, and mabe its cracked and coolant is leaking from there, but I never heard of that, Im soo at a lost I dont know where to go from hear, any suggestions
