I installed an after market boost controler and when I turn it down I can make less boost but even when turned all the way up I can only make 6 psi, should I put washers under my wastegate? Your thoughts please
supraguy@aol;2041725 said:And that's about as far as you wanna go. Any more than that and you start hitting boost cut anyway.
