Why a 1JZ Flywheel with an R154?
s13maniacs
13
Woodbridge VA
First post and it might sound dumb but why is it that I need to use a 1jz flywheel on a 2j motor for the r154 trans? I know that maybe the clutch splines are different but that can be fixed but ordering a resplined disk.. Is size of the disk or bolt holes on the flywheel for the pressure plate that are different? Im going crazy here lol help
IBoughtASupra
4,455
Queens, NY
You need to because the pressure plates are different in relation to the transmission used.
R154 - Pull
W58 - Push
Check the JZ thread, I added the difference there.
s13maniacs
13
Woodbridge VA
R154 - Pull
W58 - Push
I know I didnt specify the question but I wanted to know between the GETRAG and the r154 but Ill take a look at that thread now... Thanks
