Who Wants To Be The Hero!?
jony89
159
LongBeach
SO! There is a common question us guys ask that are doing a 7mgte swap for the first time. I have done my research and there is no clear answer to this question!
What exact plugs do you need to repin to make the body harness work for a 88 7mgte swap into an 89? Does the 89 body harness and computer (not ecu) stay on the 89 and all that needs to be done is use the 88 clips (repined) to work with the 89 computer? or does the whole body harness 0f the 88 have to go on the 89?
If anyone knows of a write up or can make a write up this will probably be the last time this question is asked! :1zhelp:
